No idea whether this could even be possible. But i have a fender GTX modeling combo and at times the footswitch will go off on a bender by going into tuner mode by itself, freezing etc. Thing is, i play it 95% of the time at home and play parties or jams with friends maybe 6 times a year. That seems to be the times it happens and most places are not bars/clubs where you would encounter lighting that might bug things. So the only thing playing at home and jamming with friends/parties don't have in common is my bass player uses wireless. So i as wondering if that could cause it. Not sure what the GTX switching system is but it has a ton of functions and the cable is 2 conductor, tip and ground. I think that may tell you what kind of switching it uses.
modeling amp switching glitches....can wireless cause this?
The cable to the pedal is simple because the pedal system is digital, so a data stream communicates between amp and pedal. I suppose anything is possible, but I cannot imagine a way for a wireless unit to affect it at all.
DO you use all the same cables when you are out and about? Same power source and distribution? (ie different power strips, or someone's old basement wiring) Some place might have ground and neutral inverted in the wiring. Most of the time you'd never know the difference.Education is what you're left with after you have forgotten what you have learned.
Originally posted by daz View PostThing went wacky for a minute till i un/re plugged it.
I had a Vox modeling amp, bought used. When it was turned up loud enough, the vibrations of the cabinet could cause the top panel controls (encoders) to move enough to change the parameters, etc.. Annoying. That doesn't sound like what you're experiencing, but I thought I'd throw that out as well.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View Post
The foot pedal or the amp? If it's the pedal/cable combo, might be humidity or a light corrosion on the connectors interfering with the serial comms. My guess.
If 're-boot' always fixes it, I always suspect the AC line. Some times they don't use low dropout regulators and you might be using it in other areas that are a bit lower and right on the threshold. If so, you could get a crash even thought the AC line seems fairly steady.
We used to use the variac to slowly drop the voltage and see what the threshold was for lock-ups or crashes.
You can't dismiss the AC line as a possible cause til you are actually measuring it when the fault occurs.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIf 're-boot' always fixes it, I always suspect the AC line. Some times they don't use low dropout regulators and you might be using it in other areas that are a bit lower and right on the threshold. If so, you could get a crash even thought the AC line seems fairly steady.
Originally posted by nosaj View Post
You pay shipping and i'll send you one. Send Pm if interested.
nosaj
If anyone else is lurking and wants to pay shipping i will send you one.
nosaj
addendum: It will go in a it fits it ships box about 16 or 17 dollars for shipping. Conus Canadian is international and much higher. This is and older GE variac that you mount on somethingLast edited by nosaj; 11-04-2021, 02:14 AM.soldering stuff that's broken, breaking stuff that works, Yeah!
- Likes 1
