Originally posted by Tom Phillips
View Post
General Question about European power and polarity
Originally posted by Greg Robinson View PostLine/neutral fault detection is monitored by checking for a voltage difference greater than a couple of volts between ground and "neutral". As there is no neutral in this case, that fault light being lit is to be expected.
The manufacturer may want to re-word this section:
Wiring Fault: This indicates the LINE and NEUTRAL wires in the source are reversed. Unplug the unit immediately and consult an electrician to fix the fault.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
I'm sure you are correct, but the wording in the manual will lead the layperson to call an electrician, perhaps wasting money on an unneeded service call.
Since then, they have only replied to me twice to say they are forwarding it to this guy, then forwarding it to that guy. It's a little disappointing that they do not even know about the stuff they are selling and how it would behave in the various territories they sell to...
And I had actually prepared an email for Black Lion Audio on day one, but I had even less faith in that then I did in messaging Thomann... probably unfair of me to assume they would tell me to call an electrician in, but that is what I expected. And when I wondered where I could get to the "bottom of it" - well, that brought me here of course ;-)
"'He who first proclaims to have golden ears is the only one in the argument who can truly have golden ears.' The opponent, therefore, must, by the rules, have tin ears, since there can only be one golden-eared person per argument." - Randall Aiken
- Likes 1
I thought I'd throw an update here.... I've been using the conditioner and it works perfectly fine with the "fault light" dimly light. It's actually an interesting unit, it soft starts some of the outlets for high current items.
Thomann never replied to me with anything but a return label and not sure if I mentioned, I did reach out to BLA a few weeks ago, and they only replied with a question about how it responds when I re-orient the plug, though I described to them that it acts exactly the same regardless of the plug orientation in my original message.
Arms up in the air. It works great and neither Thomann or BLA seems to be quite sure of what they are selling and how it should act in the targeted sales areas. Thought someone may get a chuckle from that... I did.
But this is a final Thank You message - happy holidays, and be safe!!
- Likes 2
