Hello I have a Mackie 1400 SN: AH15857 and the hot light stays on. The amp also randomly goes quiet and then abruptly come back to normal volume while using.
I have seen a few repair suggestions mentioning Resistor R205 and Transistor Q91 but they seem to check good. But they mentioned both being on the smaller board mounted opposite the larger board on the heat sink and my amp does not have R205 and Q91 on the small board together. Q91 is there but R205 is on the larger board (rear right corner when viewing from the back of the amp) Non of the resistors I have checked have been open. A few have been slightly outside the 5% value range but nothing open.
Can anyone help???
Can anyone help???
