Twin Reverb - Amp circa 2005 Trem issues
The end of your blue line goes to ground, as g1 states. You can't have bias voltage at the same point as a ground.
Originally posted by sparkies View Post
Its annoying they do have callouts on their schematic.
The blue bias volage to the vibrato.
- Likes 1
Leave a comment:
Originally posted by Tom Phillips View PostAgreed. At first glance someone may think that the 15K resistor from the bias balance pot wiper has something to do with the tremolo because it seems to connect to the LDR in the light bug. However, the resistor is really just connected to ground and, as g1 points out, has nothing to do with the tremolo circuit.
Leave a comment:
What balance control, and how does it relate to the opto? The amp in question is from 2005, the schematics are for a silver face that the owner would prefer the trem circuit emulate.
At least that's how I understand the issue. In either case, I don't see how altering the bias (idle current) would affect this style of tremolo circuit?Last edited by sparkies; 02-09-2024, 01:58 AM.
Leave a comment:
- Likes 1
Leave a comment:
Originally posted by g1 View PostWhat balance control, and how does it relate to the opto? The amp in question is from 2005, the schematics are for a silver face that the owner would prefer the trem circuit emulate.
- Likes 1
Leave a comment:
looking at the schematics, replace the 15k resistor on the wiper of the balance control to 33K.
- Likes 1
Leave a comment:
Originally posted by Mars Amp Repair View Post
Thanx for the tip. Unfortunately, this amp is not exactly like the schemo I attached. I'll pursue the idea, tho.
Leave a comment:
Your scope pic only shows one negative going pulse.
Could you go to a larger time base setting to see the periodicity?
I suspect the neon has gone up in breakdown voltage causing a discontinuous modulation with a long "dead time" between pulses..
Leave a comment:
Leave a comment:
Originally posted by Mars Amp Repair View PostHello folks,
I have a cust that would like the Trem on this amp to be more like the 60's versions. The trem on this amp basically just turns the drive to the power tubes on and off in a rather sharp transition, instead of it being a slower more smooth slope-type transition from on to off (or lower volume).
I really am too busy to take time to mess around with values in the ckt at this stage, so I thought I'd put it out there as I have to figure someone else has addressed this issue.
So, anyone messed with this issue & found a solution?
The trem ckt is similar to this Master volume version (this does not have master vol).
See also scope shot: Upper is drive on 6L6 grid, lower is pulse to the neon bulb in the bug.
Thanx, Glen
Leave a comment:
I have found that the abrupt modulation waveform is often due to the characteristics of the LDR inside the light bug. When that is the case, changes to the other components in the trem circuit won't fix the issue. In those cases, I try different light bug assemblies. Sometimes, from different suppliers.
Leave a comment:
Hello folks,
Thanx, GlenAttached FilesTags: None
Leave a comment:
