Help locating an alternative part
  • Help locating an alternative part
    Hi guys I'm after alternative for this encoder if you can direct me to a possibles swap I'd be most grateful
    RESV001063
    Make and model what it is from might help to source it.
      Seems to be for Novation Twitch.
        Full Compass has the part listed, but out of stock. You might call them to see how long it would take to get one. I believe that part number is the Novation #. Are there any numbers on the original part? If so, you might be able to find it elsewhere by manufacturer number. You'll otherwise need to figure out how to locate a datasheet to find how many detents, etc. What's wrong with the original part? Have you tried cleaning it?
        https://www.fullcompass.com/prod/524...der-for-twitch
