Can you please help me narrow down between these used oscopes?
    Originally posted by nevetslab View Post
    1500VDC are NOT cheap. You can find them used, if you spend enough time looking.
    What are we talking here? $100 or $1,000?
    "'He who first proclaims to have golden ears is the only one in the argument who can truly have golden ears.' The opponent, therefore, must, by the rules, have tin ears, since there can only be one golden-eared person per argument." - Randall Aiken
      A Tektronix P5122 X100 probe is a bit over $300.
      P5100A-TPP0850-P5122-P5150-P6015A-High-Voltage-Probes-56W1026213.pdf
      I found a Hantek 100MHz X100 probe that I know nothing about on Amazon
      https://www.amazon.com/Hantek-Oscill.../dp/B0030L0X58
      I'd suggest doing some research on the subject. I've always trusted my P6009 X100 probe, and had a P5100 X100 probe when I was at BGW Systems, which also worked just fine. I have some cheap $35 X100 probes that are only good for 500VDC, if that.
        For a quick and cheap HV probe I made a probe tip extension with a 10 Meg / 1 Watt (500V rated) resistor. My probe is a Tektronix P6106 rated at 500V so I should be good to 1000V.
        The HF response will be compromised but I'm looking at DC or 120Hz ripple so it shouldn't matter.
        The last probe I blew up still worked at DC but had no HF. The 9 Meg resistor was still OK, it was the paralleled capacitor that opened.
