SWR Workingpro 2x10C footswitch
  • SWR Workingpro 2x10C footswitch
    Simple one: could anybody provide the pinout for the 5-pin DIN footswitch connector found on the SWR Workingpro 2x10C combo?
    It is supposed to switch the Mute and Bass Enhancer.
    Thanks.
    Thanks.
    I don't know if they are the same, but the Workingman 400 head uses the following pinout:
    1-Mute Foot Switch
    2-Ground
    3-Bass Intensifier Foot Switch
    4-Mute LED
    5-Bass Int. LED
      Workingpro 2x10c
      ON THE CABLE TO THE INNARDS:
      1. Mute FS
      2. Mute LED
      3. Analog ground
      4. Bass Int LED
      5. Bass Int FS
      THE DIN CONNECTOR ITSELF:
      1. Mute FS
      4. Mute LED
      2. A gnd
      5. Bass Int LED
      3. Bass Int FS
      Note that is the order of pin numbers around the arc of pins on the DIN. They are not in straight 1-5 order.
        Wow, quick and specific Thanks!
        Enzo, if I may go one step further: any specifics on the LED voltages, switch sensing? I presume it is all simple and straightforward, but if there is any potential stumble, pls point out. Cheers.
          Beats me, I'd expect plain old LEDs and switches.
          The circuit appears to be simple switch to ground at each control input. The LEDs appear to be anodes to ground. The circuit powers them when needed.
            Thanks again for the efforts guys!
