fet channel switching schematic
  • fet channel switching schematic
    I am in need of a FET switching mod that I can install in my
    2 channel amp. The current scheme is noisey and uses a footswitch with a stereo chord. I would like to eliminate the external signal and switch internally.
    Please advise.
    What's the amp? Schematic?
    JFETs cannot handle voltages of over 40-50V, so in a tube amp, you need to put them in locations where you are certain you won't go above that, or use some other switching method e.g. relays.
