Korg AG001 host connection cable
  • Korg AG001 host connection cable
    Hi all,
    I am looking for pinout of the AG001 serial communication cable used by Korg to host computer connection.
    This cable has 8-pin Mini DIN male connector at the one side and DB-9 female connector at the other.
    I have checked few suchlike computer cables and detected to my surprise that all
    they have different schematics (Apple’s cable has non-standard RS-232 connections,
    Macintosh’s one has RS-422 connections and so on…).
    For this reason, if somebody has Korg genuine AG001 cable, it would be very appreciated
    if you could take some time to find connected pins and send pinout as a connection table
    or schematic.
    Connectors pin arrangement is attached for reference.
    Thank you in advance.
    So what goes where?
    The DB-9...
    The 8 Pin Mini-DIN.....
    I was under the impression that serail data across a DB-9 connector was a standard.
    EIA-232.
    Link: The RS232 Standard
    Link: Tech Info - RS232 Cables and Wiring
    Link: RS232 serial cable pinout information
      The following models used this serial interface:
      AG10 / C-8500 / C-4500 / Ci-8600 / Ci-9600 / Ci-800 / C550 / C-560 / C-900 / C350 / EC120 / EC320 / EC350 / i30 / is40 / i5M / i5S / iX300 / N1 / N1R / N5 / N5EX / NS5R / NX5R / 05/RW / X5 / X5D / X5DR / 05RW / Pa80 / TRITON Classic / XC1000, / XC2000 / XC3000if / FC500
      Source: Korg
      It was designed to connect with a straight pin-for-pin lead to Apple Macintosh computers with a standard 8 pin min-DIN lead as used for printers and MIDI interfaces. Korg's own lead was called AG-002B.
      For PCs, a Mini-DIN 8 to 9 Pin D lead is used called AG-001B. This is how it is wired:
Name:	Korg AG-001B & AG-002B Serial Leads.gif
        Source: Korg
        [ATTACH=CONFIG]17671[/ATTACH]
        I have already received this information a year ago.
        But I want to thank you in any case.
        casinolevant levant casino
