This has a transformer to drive the reverb tank and different circuit and values.... I compared many Gibson schematics and had no luck...
Epiphone EA-32 RVT Comet ... Not like GA-15 RVT Explorer
My Epiphone EA-32 RVT is nothing like the GA-15RVT
Originally posted by 1ampman View PostGot it ! Google Gibson Amp Heaven.... The amp I have is combination of different Epiphone/Gibson amps. Odd bugger.....
There often is not a "the" schematic for old Gibson/Epi models. I have one model in my files that I have SIX different schematics for. And a model might be one thing one year, then later the same model number winds up with the innards of some totally different model inside. They changed them all the time, and in addition to the various versions, there were also transitional amps with no documentation at all.
But they did usually have a family resemblance, so to service the amp, I could usually say this power amp and that preamp, but with those reverb and trem circuits - put them all together, et voila. If I had a matching power amp circuit, and power amp was what I was servicing it didn;t matter if the preamp part was wrongEducation is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThere often is not a "the" schematic for old Gibson/Epi models. I have one model in my files that I have SIX different schematics for. And a model might be one thing one year, then later the same model number winds up with the innards of some totally different model inside. They changed them all the time, and in addition to the various versions, there were also transitional amps with no documentation at all.
I finally did find a schematic for my Epiphone Comet EA 32 RVT although it is labelled GA-15 RVT. Here is a link to it http://frankconsiglio.com/schematics...5-RVT-1965.pdf I changed all of the caps and old resistors, rewired the Power Section and re-flowed solder in all the wells on the board. It now works ok.
francuccino
I have the same or similar problem as you did 2 years ago.
Your supplied link no longer points to the schematic you found.
I was unable to find it on the "Gibson Amp Heaven" site either.
Could you post the schematic that you mentioned in your post, or a link to it?
Thanks In Advance!
earache
Posting this here to see if it might be the one...? As with Gibson scheme's who knows?Attached FilesWhen the going gets weird... The weird turn pro!
