Schematic Request: Crate GX-60C
  • Schematic Request: Crate GX-60C
    Hey everybody,
    I'm finally getting around to fixing up my blown out Crate, and need some help! I've already replaced two popped IC chips ( TDA2050V's ) and need to replace two resistors; the only problem is that I can't make out the color code on them. If someone has access to the schematic, or has the amp and is willing to undo about four screws, I just need the value / color code on resistors 127 and 129, just below the two largest capacitors on the board. Thanks a bunch.
    If no one else steps forth, call Loud Technologies & ask for the schematic.
    All that they ask for is a serial number & a returned disclaimer.
      Oh really? Awesome! Thanks for the advice, JazzP.
        Here is a link to a GX40 that uses the TDA2040's... Your unit is probably very close with just using the TDA2050's instead. The part values will be very close... compare other parts.
        CRATE GX-40CDSP GUITAR-AMP SCH Service Manual free download, schematics, eeprom, repair info for electronics
        Scroll down to "get manual" and click to download. Ignore other download links.
