Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
Hi Oleg.
What will you use it for?
Amplification / switching / compressor?
It's a very common and generic FET, as plain vanilla as they come.
I *guess* that being in Russia, you have access to European types, such as BF245 and similar ones.
In that case, suggesting a "J-something" or a "2N-something" *may* be not be available locally, so we need to know what you will use it for.
A schematic (or least the part where it works) will help a lot.
Hi J M Fahey!
Transistors was appl in the scheme of a muting, on characteristics anything close are not present, the main thing - resistance of transition (it are no more 30 Ohm).
Part of the scheme I attaches, on the scheme VT1 & VT2 transistors.
Hi Oleg.
Markus Bass has given you a way of getting the real thing, closer to home.
If you are in a hurry and don't want to wait for delivery, that muting circuit is the easiest function to accomplish.
Buy a few cheap N Channel Fets, (ironically, the cheaper the better) and measure Drain to Source resistance, select the lower ones.
Keep the others for future use
**Just double check pinout, they may not be the same**
