I'm looking for a Flextone III service manual or something that gives the test procedures for the self check functions. The amp comes on all the LEDS light up then go out, nothing after that. I've tried the A and D channels reset procedure and the 4 lights come on but nothing happens. I realize Line 6 is a tough one but hoping some one out there can help. Thanks,
Schematic for a Line 6 Flextone III
Originally posted by Bob W. View PostThanks, that I did. checked all the supplies and they were dead on. Bob W.
Is there any voltage on the outputs? AC or DC?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Here is a link to the Line 6 Flextone II (the page is mislabeled as the III )
Link: LINE-6 FLEXTONE 3 SCH Service Manual free download, schematics, eeprom, repair info for electronics
It probably is not the same as the III.
But, it may give you some insight as to what the designers where doing. (crack?)
The main cpu drives two ic's that drive the LED's.
The main cpu needs a firm clock signal, so you may want to check that first.
I have the complete manual for the Flextone 3. I don't remember where I found it.
It's 35M so I can't post it here. I've extracted the test procedure, an external
computer is needed for some of it.
Doug
This is what I get when I try to attach the file. Send me your email address in a PM
Fatal error:
Could not create file system directory to hold your attachment.
Unable to proceed with save while $errors array is not empty in class vB_DataManager_AttachmentFiledata in [path]/includes/class_dm.php on line 849
Originally posted by nosaj View PostSo go backwards from output then. Most chips if you can read them you can get the info sheet on them that tell you what they do. So you know where to check for audio at. Maybe it is making noise an not coming to speaker, output , etc?
nosaj
Originally posted by dmeek View Post
