Enzo, I was looking for the Sunn Sorado, solid state rectifier version which I assume you linked up here but that link is now defunct. I have a 1972 on the bench. Do you have that schematic or a working link you could share? Thanks! JG
Wait for the page to prepare the schematic. Then click on "Get Manual" to download it.
It's the same amp as many other Sunn amps, including my Sentura II. Would should be able to help you get it going pretty quickly. There is one thing you need to check right away. When you power the amp, how much voltage is on the first (30 UF) capacitor. It's rated for 525 volts. These amps want to put 550 to 600 on them.
