Ultrabass BX4210a
  • Ultrabass BX4210a
    Hi am needing schematic diagram for Behringer Ultrabass BX4210A or something similar for a freind to fix my amp. send to my email if you cant post thankyou
    help to fix my bass amp - YouTube
      I am not too sure what that was all about.
      Anyway, I believe the BX4210 output section is a Class D design.
      If so, here is the schematic for the amplifier.
        A bit more descriptive text would be useful here rather than a tube video i.e. what the fault is and what you are trying to achieve.
        Tracing back the connections with a continuity tester should give you a rough idea.
        My guess of what that 6 pin connector carries is based on the BVT 4500h.
        Plus and minus 15v supply and power supply ground. (Pins 1,3 & 2)
        Output from pre-amp post master vol and audio ground.(Pins 4 & 5 )
        Limit L.E.D. drive from power amp. (Pin 6)
        Hopefully someone has had hands on experience with this and or the correct diagram.
