Peavey 5150 Schematic Request
  • Peavey 5150 Schematic Request
    Does anybody have a copy of the Peavey 5150 schematic? All the copies I've found on the forum so far apparently were in the forum database that was "lost" and are not viewable. I have a request in to Peavey, but this is a rush job. The amp was brought back from the UK with a 220/240 power cord. I have swapped the cord for a 120V, but I don't know if the power transformer is configured for 120V. Would like to know what the transformer power output is supposed to be before I go much further on it.
    Thanks in advance! -Ed
    The export transformer is for 220/240v and is part number 70519327. The domestic USA transformer is for 120v only and is part 70518727. Look on the transformer to see which you have. I suspect you will need a new transformer.
    If in doubt, look inside the amp. There will either be wires for a dual primary or there will not.
      Just to add, the information that Enzo supplied is all you will get from the schematic.
      The transformer wiring is shown as wire color.
      Edit: Renamed file:'5150 Combo'
        Did you click the wrong one, JP? That is the combo.
          Ooops.
          I renamed the file.
            Here's a section from the 1992 schematic seems there was a choice of 3 power transformers -Domestic,100v and export.
              Thanks all, for the help. I found out that the 5150 head (not a combo) I'm working on does have the 70519327 220/240 Volt export transformer. Have to order the correct one Monday. I read where the +/-, 220/240 switch is not used on the domestic version, but is wired in on this head with the 220/240 transformer. Do I have to disconnect or do anything with it after I sub in the 120 V transformer?
                I would completely disconnect the switch and also I would order that the inrush limiting thermistor (TH1) Peavey part number 70240200.
                Don't forget the fuse change to a 5 amp one. Just follow the diagram in the 1992 schematic jpg I posted.
                  And somehow figure out a method to mark the amp as 110V/5 amp.
                    The 120v transformer won;t have wires for the voltage switch. When you remove the 240 transformer, just leave the switch terminals empty.
                      Again, thanks all. -Jazz P Bass: I think the amp started life as a U.S. version and had been reconfigured for foreign use. It is marked on the chassis at the power cord exit as 120V/60Hz and the 220/240 select switch location is marked on the chassis with the + neutral - markings.
                        Round & round she goes.
