Ce_anCe AM-301 amp
  • Ce_anCe AM-301 amp
    Hello Schematic collectors...
    I have a Chinese power amp, which appears to be 300 watts per channel at 8ohms. I never heard of the brand Ce-anCe or model AM-301. It has two problems where a schematic would really be helpful, a low ticking sound from either channel when driving a load to just below clipping, about 4 volts before clipping. Monitoring the power supply rails reveals no noise. The ticking is about 1/100th the rate of the waveform. The second problem is one channel is intermittent in coming out of standby on cold start turn-on delay.
    Anyone have a schematic for this amp?
    Company info: Ce-anCe Electronic Technology Co.,Ltd.
    ADD:No1-1 Xinping South Road, Enping City, Guangdong, China
    TEL:+86-750-7776000+86-750-7776001
    FAX:+86-750-7776002
    Website:ce-ance electronic technology co.,ltd.
    Mail:ce-ance@vip.163.com ce-ance@ce-ance.com
    Link to amp spec's: AMPLIFIER AM-301 - China AMPLIFIER AM-301
    Link to resller: CE-ANCE
      Thank you Jazz P
      I wrote to them last week and got a reply that it was an old model and they did not support it any more so I figured I would try here. I made progress on it tonight but was hoping i did not have to draw out the diagram. The amp itself is now fine after finding a diode the was leaking at 64 volts but working at any v below that level. After replacing it I swept it with my curve tracer and sure enough it was breaking down at a finite reverse voltage 140 v too low.
