Wharfdale pm700 schematic??
  • Wharfdale pm700 schematic??
    Wondering if anyone has Wharfdale pm700 schematic, as Wharfdale is not responding to email request.
    Thanks,
    Jason
    I too have been searching for this schematic, to no avail. I have emailed them too. No answer.
      Well does any one have an idea to troubleshoot low output? The volume is very low.
      Thanks,
      Jason
        Start with fx send/returns to check if its a preamp or power amp problem.
          pm 700 schematic
          Thanks,
          Jason
          here for you ,regards from sonora mexico
            STAX. Thanx a million.
            Tell me, do you have one that's a better quality. When I open file I can't see any values. Too blurry..
              I found that if you install Sumatra PDF Sumatra PDF reader
              That it renders the file correctly, nothing else I tried would work right. But sumatra pdf works fine, used to use it years ago.
              Good luck.
              nosaj
                Even using Sumatra, it is blurry.
                It looks like a bad scan attempt.
                  I'm able to read it all. Before in adobe it was blocky letters like a font problem. With sumatra schematic info is a light shade of grey but component values are clear to me.
                  Nosaj
