Anyone have a schematic for a Samson S500?? I have one here with no output from the 1st channel. Got it with the volume pot broken off the PCB. Even when replacing the 10K volume pot with an alpha 10K I have here there is still no signal at the speaker. 2nd channel works fine.
Wondering if this is the wrong pot somehow or, if there is another problem breaking the signal path. The replacement pot is 10K audio taper but it does not fit the footprint of the PCB. Had to wire it in.
This amp:
This amp:
