Wharfedale Pro S2500 circuit
  • Wharfedale Pro S2500 circuit
    Need Circuit or service/ repair information on S2500 Wharfedale amplifier many thanks fez2
    what is the fault your having?
      hello,, the map will not power up and a visual inspection shows R112 blown apart think it is part of the soft start up circuit, so looking for diagram etc..
        Hope, this helps.
          hi paleeman excellent just what I needed,,, many thanks fez2
            Hello paleeman, any chance of having the service manual for the wharefedale s-1500 too?
              Hi Jaysgr. Here it is. Use it wisely
              S-1500.pdf
                You're the man paleeman!! Thank you very much!!
                  Hey there, did you end up finding a suitable part? I have the exact same issue, thanks, Jet.
                    It's right there in the service manual (post #4). Right off the AC line. It's an NTC thermistor. There's even a parts list with a part number for you.
                      R 112: https://www.ebay.com/p/1-Ohm-30a-Pow...pcs/1752945068
                      R 213: http://www.datasheetcafe.com/ntc-10d...tc-thermistor/
