Line 6 Spider Valve M2 112.
  • Line 6 Spider Valve M2 112.
    Hello there. I've only just joined this site so finding my around a bit here.
    I need a circuit diagram for a Line 6 Spider Valve Mark 2 112, specifically the front panel board. I am getting no joy from Line 6 Europe so thought I would ask on here. Incidentally, Yamaha UK (Dear Dusty) is now taking on service for Line 6 products in the UK but they don't have any info as yet as this change has been so recent.
    Problem I have is the pot that selects the "Clean" "Blues" "Twang" "Class A" sounds has collapsed and I've no idea what it is. I'm guessing at B 68K but it is so hard to get a decent reading from it so could really do with some help here.
    Thanks very much.
    I think that you have in mind rotary encoder with switch.
    Line 6 does not provide its manufacturer's part number,
    but you can try to order it using in-house number 24-12-0010.
      Hi Doctor! Thanks for your reply. No I know what you're thinking. That switch is on the front far right of the front panel underneath the LCD display (preset push to edit). The part I need is on the far left. next to the guitar input. there are three other "effect selectors" pots, I'll take measurements from them and assume they used the same part for the one I need replacement. I'll try and figure out how to put a pic up on here!
ID:	837351Click image for larger version
ID:	837352Click image for larger version
          maybe this is the one you need
          The part you need definitely seems to be a potentiometer
          The sch & parts list doesn't seem to list the value, but all these pots go into an A_D converter, so they should all be the same value, and even then, the value is probably not critical, as the pots go between 0V & 5V and the A_D looks at the wiper voltage, the pot is a voltage divider only. Depending on the voltage at the pot, the micro then turns on the appropriate "mode" led & selects the mode (crunch / clean etc)
          The pots look to be ALPS type RK09 or similar, should be easy enough to find on digikey (or similar), or your local parts store.
            Aha! Thanks Mozwell. That's grand mate. I shall plough on with this tomorrow and let you know the scoop in the next few days ok.
              Sorry for the delay but all in well with this one once more. Thanks for all you help Mozwell and Doc... :-)
                Most of these Line 6 amps use the same 10k pots which are available from Full Compass.
                Drewline
                When was the last time you did something for the first time?
