Trace Elliot AH250
  • Trace Elliot AH250
    I have a Trace Elliot AH250 amplifier that has some issues. I need the schematic but can't find it... Help!!!
    If nobody bellies up, contact Peavey, USA.
      the AH500 may be what you need.
      I am not familiar with the amp, but the AH250, may be the AH500 with one power amp only
      AH300 & AH500 attached
        Okay thanks! I haven't got a clue actually. Guess I have to open it up and see if it is a one power amp version of the 500.
          Or maybe... Anyone got a suggestion to schematic I can use to rebuild this sucker..?
            Are there any more numbers on the Model?
            AH250 GP11 MKIV?
            AH250 GP12 SMX?
            Oh. What is wrong with the amp?
              AH250 GP11 MKIV?
              AH250 GP12 SMX?
              Ill have to look it up, I don't have the amp here in my home...
              Major suspects are transistors or fets. I don't have that much experience from SS amps.
                If not remembering wrong, the 500 is 2x250 under a single hood, so 500 schematic should do.
                And 350 should be the same as 250 with an extra pair power transistors.
                  Found on chassis (in addition to T.E. 250 etc... ): GP11 Graphic preamplifier Mk V
                    I called Peavey.
                    This is what they have.
                    Take note that on the power amp page, the box states it is for AH150 & AH250.
                    So you should be good to go.
                    trace elliot GP11-AH350-AH500-MK-V-BASS.pdf
                      I think I'll have a go at the power transistors, judging by the schematic they seem to run quite hot. Maybe they're just worn out..?
                      Eh.. Maybe I should open a new thread on this project in an appropriate section. I'll be back!
                        And in the new post, be sure to mention the symptoms you are trying to cure.
                          Aye aye captain! *stands in attention*
                            As you were. (stand easy)
                              Generally if output transistors are running hot, it is due to a problem elsewhere, such as misadjusted bias.
