line 6 HD100 mkII spider valve schematic?
  • line 6 HD100 mkII spider valve schematic?
    Can't seem to get hold of it... Just need to find out what the drive pot is so I can replace it
    Line 6 don't give out schematics
      Thought so , think this is the pot I need 10k Pot but they don't ship to the uk
        This might be close enough Line 6 HD100
          Thanks! Would u happen to know the name of that type of pot?
            It looks like the ones Marshall use in the MG https://www.cedist.com/products/R-VMG-10KL If it is, that shouldn't be so hard to get hold of.
            >This< looks like it will work but you'll need to file a flat
              Not sure - the APLS RK09L look close. Measure yours and compare.
              >RS< have them
                Thanks! Il prob order those ones
                  Line 6 defines this pot as “pot mono 10KB linear taper 25mm W/9mm Nut D-shaft”
                    Has the OP tried contacting ANY authorized Line 6 repair center???
                    I have purchased Line 6 items from the local guy in Allentown, Pa.
                      I think this may be the schematic you are looking for. Send me your email & I will forward it to you. The forum will not let me upload it.
                      Drewline
                      When was the last time you did something for the first time?
                        Thanks guys. I got it sorted, the pot Nick suggested done the trick!
