My friend Felix talked to his friend N. Schon about the Victory amps he was playing at Bananas in San Rafael today and Neil was really impressed with the $1299 30W pcb head (clever way to name drop while avoiding Google searches, eh?
V30 The Countess - Victory Amplifiers
I doubt that a full schematic for this amp is available but I was wondering about the power output switching... theories if not facts. Thanks!
Features & spec
Format: Two-channel head
Power:
Clean Channel High Power: 42 Watts
Clean Channel Low Power: 7 Watts
Clean Channel High Power Single-Ended: 1.6 Watts
Clean Channel Low Power Single Ended: 0.5 Watts
Dirty Channel High Power: 37 Watts
Dirty Channel Low Power: 6 Watts
Dirty Channel High Power Single Ended: 1.2 Watts
Dirty Channel Low Power Single Ended: 0.5 Watts
Valves: 4 x 12AX7, 2 x 6L6
Extra features: Power valves switchable to EL34, single-ended mode, effects loop, skeletonised metal case with rubber handle, padded carry bag included
SIZE (mm): 342(w)x 185(h)x 185(d) including handle, feet & controls
WEIGHT 8.2kg / 18.1lbs
Steve A.
P.S. I am really impressed that the Clean channel puts out more watts (42W) that the OD channel (37W). Usually the Clean is much weaker than the OD channel.
Features & spec
Power:
Steve A.
