Just curious, how did you measure that 6A consumption @ 48V supply if you don't have the batteries yet?
Need BA-330 Schematic for modification
I used four 12.7 Volt lead acid car batteries connected in series(50.8V) with hand made LDO regulator(PMOS IRF4905 + OP Amp LM324) to power my TAS5630 Class-D Amp Board.
I have to build these test equipment by myself since high power power supply is a bit expansive.
It takes little effort to build my test circuit but everything seems works fine.
