BOSS ME-20B schematic needed
  • BOSS ME-20B schematic needed
    Does anyone have the schematics or service manual for the BOSS ME-20B? Some components missing from the board. (IC5,C64,C139).
    Thanks in advance!
    Well, not exactly the 'B' version.
    Here is the ME 20.
    me-20.pdf
      IC5: TC7W04FK
      C64: 100nF
      C139: 100nF
        Thank you very much Jazz P Bass and doctor.
        kitt
          So it's missing a buffer ic and two capacitors.
          Were they ever there are you poking around?
          For the 'B' (Bass) version they may not be required.
          That PCB may be used on different models.
          Roland may be able to tell you.
            It's due to battery leakage. Components in the affected area loosened by the acid.
            Version B board looks exactly the same. IC5 is needed for EEPROMs.
            Thank you Jazz P Bass for giving me the schematic. I will be totally lost without it.
