RODE NTK MIC
  • RODE NTK MIC
    Anybody here on the forum have a schematic for this MIC and Power Supply??? I have one here that is causing a crackling sound after it warms up..sometimes it will take longer than others.....The tube has been replaced but the problem remains.......can't see anything obivious....
    Cheers,
    Did you contact Rode and ask them for it?
      Yes i did...I contacted the Canadian Distributor......Haven't heard anything back yet......
      cheers
        May I suggest, unless they reply in the next day or two, that you CALL them. And also, a distributor is not the manufacturer, so try contacting RODE themselves.
          I thoroughly agree with Enzo.. contact Rode.. they may not supply schematics but will offer support.
          The NTK mic according to the Australian web site
          RØDE Microphones - NTK
          has an extended 10 year warranty if you registered your mic in the first year of purchase.
          I have found Rode to be excellent with their response and backup.
          Check the tension of the tube socket pins .. and use the old one to spray some deoxit on it's pins and work it in and out a few times.
          Can you borrow another PSU ? or hang a o'scope on the unit and see if it's spitting !
            A quick check on their web site gives service agent / distributor as
            6-1275 Newton Street
            Boucherville, Quebec, J4B 5H2
            Canada
            (450) 449-8177
            info@adi-online.net
            Audio Distributors International | We know music.
            I assume these are the people you have already contacted
            Failing that, contact Rode in Australia by email info@rode.com RØDE Microphones
            Or by phone +61 2 9648 5855 2pm Vancouver time is Sydney 9am
            I have several Rode mics that i use for micing guitars and drum overheads, they are great mics.
            I have not had to deal with them for service, but i think they would bend over backwards to help you.
            If the unit is under warranty, then you should be able to get it repaired under warranty
            RØDE Microphones - Contact under "change country" select Canada
              Canada
              (450) 449-8177
              info@adi-online.net
              Thanks Moswell....I contacted them already in Canada....I sent off an email to Rode in Australia....Hopefully I will hear back from somebody soon...
              Cheers
              casinolevant levant casino
