Trace Elliot AH1000-12 schematic needed
  • #91
    If you do keep the filters clean, it is a win win.
    • #92
      Originally posted by Roberto View Post
      Do you guys suggest to add "sponges" before the fans, to filter out the dust from the cooling air?
      Fan setups that have these kinds of filter, the filter material looks to me an awful lot like a scotchbrite pad. There are several varieties of scotchbrite. If I were to add/replace this kind of filter I'd pick a likely looking scotchbrite or similar scrub pad, cut it to size, install it and smile. When it starts looking loaded with dust simply remove, wash out with detergent & water, rinse, air dry & reinstall.
      • #93
        Thanks guys.
        • #94
          I buy filter material for dehumidifiers. You can get it in large rolls at most hardware stores. Just cut off the size you need.
          • #95
            Thanks The Dude!
