Help please Roland Cube CH 60 (Cube Chorus) schematic needed
    nosaj, doctor,
    thanks a lot!!!!
    It is the schematic!
    Trouble solved: electrolitics changed, treble pot and overdrive input restoration made.
    Thanks!
    Best,
      Hi,
      do you know the responsible IC for the reverb ? The reverb in my cube is dead...
      Thanks and regards
        Originally posted by Torsten View Post
        Hi,
        Thanks and regards
        First check coils in reverb unit.
        IC1 (4558), Transistors Q1, Q2, Q6
        It's All Over Now
          Hi,
          Thanks and regards
          Hi!
          others similar models, like the old "orange" roland cube, worked with a power IC in the reberv drive. Its works with a OP and dicrete transistors as driver (more universal replacements!) The input reverb coil impedance is 8 ohms.
            Hi,
            ...thanks all. Checked the reverb unit in a different amp and it's OK. Also changed the IC, but no reverb at all. So try to change the transistors Q1, Q2 & Q6 as well and hope this will solve the problem.
              Originally posted by nosaj View Post
              [ATTACH]50101[/ATTACH]
              Here it is.
              nosaj
              thank you man, that's it))
