Behringer Europower PMP5000 Schematic nedeed
  • Behringer Europower PMP5000 Schematic nedeed
    Hey people does anybody have Behringer Europower PMP5000 Switching Power Supply schematic, and an Amp board schematic?
    What are the board numbers? Is the amp an HCA2400 maybe, and the power supply maybe SPS1000?
      PS schematic: Behringer HCA2400 DPA.pdf
      Take note that the driver IC (IXD404) is not available anymore.
      It can be replaced by the IXD604 though.
      IXD_604 SI.pdf
        Yes exactly!!! HCA2400 I got from above replies all I need is SPS1000/02 now please!
          SPS1000 schematic: SPS 1000.pdf
            Thanks !!!!!
              The above HCA 2400 DPA pdf is Sheet 2 of 2. Does anybody have Sheet 1 of 2?
              I have a problem with C92 which is electrolytic SMD cap. Accidentally I bumped it and it fell of completely with the board traces.
              I need to make some bridges with wires and I need to know where to connect.
                C92 is at the input, it connects between X11 pin 2 and R126. + end towards the resistor. That is the INPUT B circuit.
                C92 is the equivalent to C93 in the INPUT A circuit, which use as a model.
                It is a 4.7uf 25v part.
                  Thanks, I would still love schematic if possible :-)
                    Here is the HCA 2400, Pg 1 & 2:
                    Behringer HCA2400 Digital Power Amp (Rev.F) Schematic.zip
