I've found lots of Bugera schematics, but I have not had any luck finding the schematic for the T50 head. I have one that I'm just starting to work on and having the schematic would be helpful. Is there a copy floating around? thx
Bugera T50 Schematic
Not one I can find. I'm starting on a ibanez tone blaster myself with a schematic. A few datasheets should make up for a schematic.
nosajBinkie McFartnuggets:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
Originally posted by vintagekiki View Post
Based on your other post mentioning a possible issue with the infinium circuit. The V22 also carried the infinium circuit mostly likley cut and pasted from amp to amp with minor changes.
- 1 like
Happy holidays, T50 folks...has anyone unearthed a schematic yet? I'm hoping for an Xmas miracle, and one to surface... The 2nd channel on these are SO bad, that I'm compelled to duplicate the 1st channel (if I have to back-track every trace on the board). THX <?>
I apologize, I should have followed up on the result of this.
I never did find the schematic, but I did get my the T50 repaired.
After struggling to figure this out without the schematic, I reached out to Bugera (Behringer) and inquired about the warranty. Even though I didn't have the receipt, they repaired it under the 3 year warranty, including shipping both ways. I know they get bashed on a lot of sites, but they really did right by me.
The Repair Order Form listed the fault as "bad master volume pot/ic1" and the Work Carried Out as "replace main pcb/tubes as preventative maintenance. Full test."
I guess that kind of makes sense since I had output from the preamp.
FWIW, I like the drive channel for heavier classic rock tones. It does depend on the guitar/pickups though. It can get muddy or buzzy with high output pickups, but I can usually dial that out.
- 1 like
