Hughes & Kettner Statesman Dual EL84 service manual
  • Hughes & Kettner Statesman Dual EL84 service manual
    Hi, guys, greetings from Brazil!
    I know it's very hard to find, but, anyone have the schematic of this amplifier? I have one in the bench now with burned resistors in the output path.
    Thanks in advance.
    Have you tried contacting Hughes and Kettner directly?
    http://hughes-and-kettner.com/support/contact/
    If no luck there, please post some pictures. We may be able to figure it out. There are only so many ways to build a dual EL84 amp.
      Hi, The Dude.
      Yes, i tried more than three times without any response.
      About the pictures, i'll provided later (i don't have a good definition camera now).
        What are resistors?
          I'm pretty sure Dr meant to say " What are the resistors?" i.e what are they connected to? Do they look like high or low power ones? A picture would help.
            I was referring to the resistor numbers, for example R45.
              Dear Doctor and TheDude,
              Thanks to your help and sorry for my later reply.
              After some searching, i found the right values of resistors (unfortunatly, because the Covid19 i'm very far from my workshop in these days), here is:
              - R59: 1K/3W;
              - R73: 1K/3W.
              Both are in power stage (open). The two output tubes (EL84) has died, too.
              R82: 220K 1/4W (power supply), show some burn marks.
              I ordered these parts from a local dealer and try to return with the whole picture when i received it.
              Again, thanks for the support.
                Dear Gansoguitar
                If you have Statesman Dual EL84 service manual or schematic please share or upload on music-electronics-forum.
                Maybe some other user will need it.
                Thanks in advance
                vk
                It's All Over Now
                  "- R59: 1K/3W;
                  - R73: 1K/3W."
                  Screen resistors.
                  Try this Tube 20 schematic for the output section.
                    Originally posted by vintagekiki View Post
                    Dear Gansoguitar
                    Thanks in advance
                    vk
                    Dear vintagekiki,
                    ​​​​​​Unfortunatly i didn't have it, i just get the information based in an photo from one guy in internet, but it helps to elucidate these parts.
