Need help finding Marshal Origin 20 schematic
  • Need help finding Marshal Origin 20 schematic
    Anyone help a guy out? Thanks in advance!!
    This is what I have:
      Is there a particular area of the circuit you are trying to fix?
        Want to look at the circuit and see if there are any tweaks I can perform to give it just a "little more juice".
          You want more juice get a more sensitive speaker....Best bang for the buck with the least work.
          nosaj
            By juice I mean overdrive. I like the way it sounds but don't want to have to use a boost into the front end to get it.
              Confirm needed
                Originally posted by fewa View Post
                Confirm needed
                That is pretty much it but there may be few errors.
                Near relay 1, R67 is 470K
                Another segment of relay 1 bypasses R63 in cathode circuit of V1b
                R55 at V2b is 220K, the cap connected to it is C30, 47n
                At bottom of PI circuit, R49 goes to ground, not to R50/NFB
                To right of PI, R41/R42 junction goes to ground. DI circuit gets signal from 16 ohm tap of OT
                Power tube cathodes are connected, then R3 and C5 (in parallel) go from cathodes to ground
                  Just thought should attribute the initial work of drawing the rough schematic with thanks to Jason Fieldhouse back in 2019.
                  https://www.instagram.com/p/B1zI_2lB0RP/
                  There are some Youtube clips by a Jason Tong from Melbourne Victoria (Aust)
                  which could be helpful in the quest for the lost chord , the holy grail - the ultimate tone !
                  Marshall Origin 20 - Headfirst mod. Tones and modding guide.
                  https://www.youtube.com/watch?v=Q_hiXjOS1Y8
                  (and no I don't know him)
