Hey people does anybody have Behringer Europower PMP5000 Switching Power Supply schematic, and an Amp board schematic?
Behringer Europower PMP5000 Schematic nedeed
PS schematic: Behringer HCA2400 DPA.pdf
Take note that the driver IC (IXD404) is not available anymore.
It can be replaced by the IXD604 though.
IXD_604 SI.pdf
The above HCA 2400 DPA pdf is Sheet 2 of 2. Does anybody have Sheet 1 of 2?
I have a problem with C92 which is electrolytic SMD cap. Accidentally I bumped it and it fell of completely with the board traces.
I need to make some bridges with wires and I need to know where to connect.
C92 is at the input, it connects between X11 pin 2 and R126. + end towards the resistor. That is the INPUT B circuit.
C92 is the equivalent to C93 in the INPUT A circuit, which use as a model.
It is a 4.7uf 25v part.Education is what you're left with after you have forgotten what you have learned.
