Originally posted by Dave H
View Post
Still no break-up. 2x 5F1's.
Originally posted by Dave H View PostThen your 6V6 should be begging for mercy.
Since I don't have a 5F1 (or any single ended amps to test for a certain result) I can only assume that, for example, a typical PI swing voltage might be 120VAC or more peak to peak, so half that for a single ended amp?!?
Obviously the amp is making some big power for it's design. Maybe that's why it's called a "Champ" That could be why SC is describing these amps as mini Twins. Loud and clean for their size.
Does anyone else think the 30VAC drive voltage on a big whackadoo chord is low for achieving clipping?Last edited by Chuck H; 10-11-2014, 11:02 PM."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostDoes anyone else think the 30VAC drive voltage on a big whackadoo chord is low for achieving clipping?
That would be very valuable info.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View Postguitician in post #117 stated he had 30VAC at the power tube grids when he plucked the low E. Unfortunately he did not mention what this gave him as output at the speaker, or whether the 30VAC drive gave clean or distorted sound.
Is guitician's reading of a "plucked low E" what he considers a nominal voltage after the attack??? Meaning that the peak for a chord is much higher. And is Sea Chief's reading at "full whackage" (loved that BTW) the highest number to appear on his meter as a peak??? Meaning that his nominal voltage is much lower. All this is way to subjective to interpret with the tests being done as they are. The potential variance is huge. A signal generator would help a lot."Take two placebos, works twice as well." Enzo
Morning- thanks for the replies overnight.
[yup thread long- that why I thought start a new b'stard].
Anyway my 30 vac reading was the peak figure/ absolute max I read at max whackage (a strum may have been perhaps ~12 vac).
The Champ schematic with test signal voltages may be helpful http://support.fender.com/schematics...atic_Rev-B.pdf
Also perhaps signal generator software for pc https://www.google.co.uk/search?q=si...m=122&ie=UTF-8 or smartphone https://www.google.co.uk/search?q=si...+generator+appMy band:- http://www.youtube.com/user/RedwingBand
Hi pdf64-
thanks for those: Im sure schematic will be useful.
I looked up free signal generator s'ware, seems I need a sound card or something- alas Im sure likely way above my humble oldXP pc. Ive never even touched a smartphone let alone used one.
Audacity: DownloadWhen the going gets weird... The weird turn pro!
Yeah I am sure wavepad has a tone generator built into that package. NCH software is the company or something, so try this out... NCH Tone Generator - Free download and software reviews - CNET Download.comWhen the going gets weird... The weird turn pro!
Originally posted by Sea Chief View PostAnyway my 30 vac reading was the peak figure/ absolute max I read at max whackage (a strum may have been perhaps ~12 vac).
For sure, the strumming 12Vac will not.
There is simply not enough drive signal to slam the output tube into distortion.
Seeing that this is NOT a Fender issued product & simply a cobbled together creation, I truly believe that you are tilting with windmills.
Play the thing, add a boost pedal & call it day.
Originally posted by Chuck H View PostI thought that was low!?! Considering that we WANT the power tube to clip. It probably has something like 20V of bias. I might have expected something over 50V to be a "correct" amount.
The 5F1 circuit I have shows both 12AX7 cathode resistors unbypassed and it has output stage negative feedback. I'd disconnect the feedback and bypass both cathode resistors with caps. That would make it overdrive for sure.
