Hi Guys...i have a Laney cd630 amp, the unit is in good condition..looks hardly used in fact..it worked fine for a couple of months, but then started to "Pop" every so often..this then progressed to a loud "Cracking" sound..and sometimes makes a very loud Static noise which is not affected by the amps volume knob...the amp then looses all audio to the cabs ( but still has audio signal on front meter and the main out jack socket on the front), the unit then magically works fine again after a minute or so.
I have tried different cables,Cabs - still does it...i have even removed the front & disconnected the push on pin connector....the amp still cracks n pops through the cabs.
i Have done the old "Tap" routine - no joy..made no difference
I have looked for Arching in the dark - which was fun - nothing.
It Aint running hot - seems fine...cracking occurs after 1-2 mins or 3-5 days.
Can anyone point me in the right direction??
Many Thanks in Advance
Montycat.
Montycat.
