Originally posted by Chuck H
View Post
Troubleshooting a "Refreshed" Fender SF Pro Reverb
Ok!!! Well, somebody's been in there eh?
The orientation of the reverb transformer looks to be 90° different from what I'm use to in earlier amps. That threw me off for a second. I think those cathode circuits going to the RCA jack frames for ground isn't stock, but I've not been inside one of these amps before. Still, the component values for the V4 cathode circuit look right so try connecting pin 8 to pin 3."Take two placebos, works twice as well." Enzo
Originally posted by Sleet View PostThanks for your input Chuck. So (just to review) I need to connect pin 8 to pin 3 using a jumper wire, correct?
No guarantees how it will work out though. I can't know what sort of changes may have been made to the amp. No risk of damage to anything."Take two placebos, works twice as well." Enzo
Originally posted by g1 View PostAm I seeing things or is pin1 connected to a heater wire?"Take two placebos, works twice as well." Enzo
Originally posted by g1 View PostAm I seeing things or is pin1 connected to a heater wire? (pin8 is without connection)
[ATTACH=CONFIG]55989[/ATTACH]
" I think those cathode circuits going to the RCA jack frames for ground isn't stock, but I've not been inside one of these amps before."
Actually, this is indeed stock. I have one in my shop right now that is this way.It's weird, because it WAS working fine.....
[ATTACH=CONFIG]55989[/ATTACH]Originally posted by Chuck H View PostIt looks like that in one of the shots. Furthermore, it's hard to tell otherwise in all but one of the other shots. But I don't think so.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by pdf64 View PostJust noticed the above, 'coupling caps' seems odd, was that just a terminology error, or have ecaps been used for coupling purposes?
Confused by this, the neon couldn't flash if it's been removed from circuit?
My take on the thread is that
1/ the amp seems to have been modded as the master doesn't seem to affect the normal channel (true?); so need to verify the circuit to its intended schematic.
2/ from the bent front panel, the master volume may have received a massive bash, may be broken, and given the symptoms must be replaced, or just taken out of circuit. Hardwire the pull boost switch in the non boost mode.
3/ a voltage survey and idle plate / cathode current measurements (eg resistance and volt drop from OT CT to each plate) would be very useful.
I do have a signal generator and scope to help out. Voltage and current survey as pdf64 suggested might also be enlightening. Any pointers or starting points would be greatly appreciated.
Did you tie pin 3 & 8 of V4 and now are still having the problem?
(sorry about the heater wiring distraction)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostDid you tie pin 3 & 8 of V4 and now are still having the problem?"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostTHIS^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Thanks so much to all the contributors in this thread. I may be back with a few more questions related to this amp
