I have the original version of the Carvin V3 Head. I believe it's power transformer went out because I measure 5 ohms between hot and return of the IEC when I flip the mains "on" while unplugged. 6A circuit breaker inline tells me I know the transformer should be at a minimum 20 ohms (the circuit breaker flips off within 1 second of turning the amp on). I looked up the V3 schematic and found the transformer to be 15-10714. That's all the information I can find on it. Does anybody know this transformer by another name, who makes it, how to get a replacement, was it proprietary to carvin, any information about it? Thanks.
Blown Transformer on 2006 Carvin V3
Does the circuit breaker trip with all secondary wires disconnected?Last edited by Helmholtz; 01-20-2020, 10:20 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostDoes the circuit breaker trip with all secondary wires disconnected?
You can test transformers using the neon bulb trick:
https://www.premierguitar.com/articl...ormer-tester-1
This appears to be a pretty simple tube PT, no low voltage windings for op amps or anything, no tube rectifier heaters either.
Maybe something like the Edcore XPWR002? https://www.edcorusa.com/xpwr002
Originally posted by xtian View PostYou can test transformers using the neon bulb trick:
https://i.imgur.com/2q0eAD5.jpg
https://i.imgur.com/PoM6pCB.jpg
Thanks for the tip about edcore. I found this one https://www.tubeampdoctor.com/en/mai...nmQaCyv0E2Pek0 which shows 400mA at 345V and 7.5A at 6.3V. Assuming that website is correct, it looks like edcore does have an option to meet that: https://www.edcorusa.com/xpwr127?fbc...th-iu8XDuPIjcc Not sure how I feel about the 8 week lead time though.
So I don't have a neon bulb; however, I do have a multimeter. Using a 9V battery in the same manner he used the 6V battery, the secondary coil (700V to 120V input) only jumped to 1V each time. The highest I could get it to jump was to 4V. I would expect somewhere in the 60V range for a 7:1 turn transformer using this trick.
But I agree your PT looks toasted.
There are other methods to test a transformer. Do you have a bulb limiter? Or some other PT that delivers heater voltage?Last edited by Helmholtz; 01-21-2020, 07:26 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostYou can't replace the neon with a multimeter. The principle of the test is based on (self) induction. Disconnecting the battery interrupts the current and produces a large but short flyback voltage spike that overcomes the ignition voltage of the neon lamp. Other than a neon discharge lamp a meter conducts all the time and thus prevents a large voltage spike. Also it's too slow. The neon lamp doesn't conduct below its ignition voltage of 60V to 80V and reacts very fast.
I see your points on a multimeter vs the bulb. I don't have a bulb limiter either, nor other PT unless I pull one out of my Dr Z. I put this PT back in the carvin and turned it on again, just to make sure the problem continued to be repeatable and of course it was. This time I paid attention to the LEDs which always flash on immediately with power. The breaker popper after about 1 second, but during that 1 second, no LEDs turn on, the lamp bulb doesn't turn on, nothing even flickers. I'm fairly confident the PT isn't working at all.
