Roland cube80 problem
  • Roland cube80 problem
    My roland cube80 just stopped working. I don't know anything at all about where to start.
    I suggest by posting a schematic.
      If there is just no sound, check the ext speaker socket, its contacts are wired in series with the internal speaker and gets tarnished causing no output.
        It seems to me that the OP simply wants to know what is wrong with his amp.
        Good luck with that!!
        If the OP could kindly supply us with some pertinent info we MAY be able to help trouble shoot the problem.
        Pertinent as in:
        What skill set do you have to apply to the repair?
        What have you checked so far?
          Firstly
          1. Does the amp receive AC main voltage.
          2. Do the LEDs light up when you turn on the power switch.
          3. Check the AC main fuse.
          4. Reset amp to factory settings
          https://www.manualslib.com/products/Roland-Cube-80xl-2312805.html
          1)
          https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/38513-roland-cube-80xl-question
          https://music-electronics-forum.com/forum/schematic-requests/46998-roland-cube-80xl
          It's All Over Now
            Also, we don't know if it's the XL or the GX.
              There should be some unwritten rule here that thou shall not give a response to such a vague non-specific question. But I think R14 and C9 are probably your best bet to fix it.
              edit: Of course I am only goofing off with that response but seriously we need more information to be helpful.
                It's All Over Now
