My roland cube80 just stopped working. I don't know anything at all about where to start.
Roland cube80 problem
If there is just no sound, check the ext speaker socket, its contacts are wired in series with the internal speaker and gets tarnished causing no output.Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
It seems to me that the OP simply wants to know what is wrong with his amp.
Good luck with that!!
If the OP could kindly supply us with some pertinent info we MAY be able to help trouble shoot the problem.
Pertinent as in:
What skill set do you have to apply to the repair?
What have you checked so far?
- Likes 1
Originally posted by Lin View PostMy roland cube80 just stopped working. I don't know anything at all about where to start.
1. Does the amp receive AC main voltage.
2. Do the LEDs light up when you turn on the power switch.
3. Check the AC main fuse.
4. Reset amp to factory settings
https://www.manualslib.com/products/Roland-Cube-80xl-2312805.html
1)
https://music-electronics-forum.com/forum/amplification/guitar-amps/maintenance-troubleshooting-repair/38513-roland-cube-80xl-question
https://music-electronics-forum.com/forum/schematic-requests/46998-roland-cube-80xlLast edited by vintagekiki; 08-29-2020, 01:03 PM.It's All Over Now
There should be some unwritten rule here that thou shall not give a response to such a vague non-specific question. But I think R14 and C9 are probably your best bet to fix it.
edit: Of course I am only goofing off with that response but seriously we need more information to be helpful.Last edited by DrGonz78; 08-29-2020, 08:38 PM.When the going gets weird... The weird turn pro!
- Likes 1
