It is most probably a thermal fuse - not a thermistor.
Peavey Classic 30 II 2018
For test purposes yes you can jumper it. You should still have all the secondaries disconnected though.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I don't see how it could be 1A, the mains fuse is bigger than that isn't it? Maybe it is a 10A thermal cutout?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The part number looks to be EYP1BF134. Sadly, the only place I could find it was eBay and from China.
https://www.ebay.com/itm/5Pcs-Panaso...YAAOSwEy1eBhNU
I ordered a couple of these as they are close in spec. Please advise me as to the downside of increasing the temp by 10 degrees or so?
Thanks for your order, we're on it Thank you for ordering from Newark. We are currently processing your order. Your reference number is: 10/22/20 22.36 PM We will send you an order email confirmation once your products have been sent to our shipping department. You can view your order details and track shipping status on Newark.com If for any reason you do not receive a confirmation email in the next 24 hours, please check your spam folder or contact us at 1 800 463 9275. Order Details Newark Ref: 10/22/20 22.36 PM Date of Order: Oct 22, 2020 Billing Method: Credit/Debit Card Shipping Method: Newark Flat Rate (Over $150 USD Ships Free) (Order by 9:30 PM EST)
This is Digikey replacement for the obsolete part. 128dgrees C
Digi-Key Part Number 317-1133-ND Manufacturer Cantherm Manufacturer Product Number SDF DF128S Supplier Cantherm Description TCO 250VAC 10A 128C (262F) AXIAL Manufacturer Standard Lead Time 7 Weeks Detailed Description Thermal Cutoff (TCO) AC DC 128°C (262°F) Axial Customer Reference
When I asked about the mains fuse, I meant the AC fuse in the fuseholder. It has to be small enough that it will blow before the thermal fuse in the transformer.
That's why I figured it can not be a 1A rated thermal. Then it is going to blow before the AC fuse. There would be no point in having an AC mains fuse then.
So the Digikey 10A makes sense to me.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
