I have never come across this before. The speaker on the left was pulled from this guitar amp and has a cloth surround. The one on the right was pulled from the same model but is round with a foam surround (that I recently replaced). I've own 3 of these amps and all have had the speakers on the right. Has anyone came across the square flanged speakers in these GK amps?
GK 250ML Speakers
GK 250ML Speakers
Tags: None
I use hot pink. No one else does, so I can usually see if I've been in something before.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 3
I do not use red which is most common and easy to get by user to hide his clumsy repair attempts but something wild, such as peach with metal flakes or even better, a few drops of my classic "bluish battle grey" front panel colour which I mix on purpose and use since the 70īs.
Try to get *that* faker!!!
Same to paint some choice ceramic caps if I want to hide some circuit details.
Gooping of painting the full board is murderous, resistors re measured in 5 seconds so why bother? but ceramic caps are another thing: values are printed with numbers, not color bands, and on a softish ceramic layer, so easy to scratch off, and same size "lentil" can be 100pF x 1000V or .01uF x 50V and anything in between.Juan Manuel Fahey
- Likes 1
