What value resistor and what pins would be best to put a grid stopper resistor to try to stop oscillation on an EL34 ? Thanks.
EL34 Grid Stopper resistor
This topic is closed.
Pin 5. Resistor must be right at the tube socket pin. anything from 1.5k to 4.7k should be sufficient.
Why do you think this is the trouble? Please give details about the problem you are having."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostPin 5. Resistor must be right at the tube socket pin. anything from 1.5k to 4.7k should be sufficient.
Originally posted by ca7922303 View Post
Pin #5 only? I was thinking it would connect to 2 pins like a screen grid resistor?"Take two placebos, works twice as well." Enzo
A screen grid resistor only really connects to pin 4. Pin 6 on a 6L6 is not used, so the empty pin 6 on the socket becomes a handy place to solder something. The resistor is much more secure soldered at both ends than at just one.Education is what you're left with after you have forgotten what you have learned.
Neither the screen grid or control grid have any mandate on being connected to an unused pin on the socket. This is done by designers and manufacturers for convenience so that no component ends are floating on a solder joint at the end of a wire lead. With no information about the amp in question I cannot suggest any bridging pins on the socket because it may interfere with what exists now in the amp.
Disconect the PI outputs to power tubes. It still osscilate? If Yes than check the OT wiring track (keep away ot primary wires from inputs wires, secondary common directly to output jacks and from those point to nfb retour) . 100 ohm screen grids close to the socket should be able to cure any . If osscilation stoped with PI disconected check then the PI stage. First wiring track, specially the wiring from OT to nfb injection point."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
- Likes 1
1 Photo
Originally posted by ca7922303 View PostHere's a photo of V7/V8. I'm not seeing any resistors attached to pin #5?
I assume they connect to pin5?
If so, what’s the resistance between the green or blue wire and the respective socket terminal.My band:- http://www.youtube.com/user/RedwingBand
