Originally posted by catalin gramada
View Post
EL34 Grid Stopper resistor
This topic is closed.
Originally posted by catalin gramada View PostJudging by you picture the wires are posed in original position. But still you may try to switch the connectors of dark blue and green to the board. Be aware you amp may severe oscillate if I.m wrong, so keep an eye on it to cut the power off quick if happen.
Ok I see now. Well you tested nothing valuable in principle cause the nfb circuit was not opened. You removed those link between blue/green points but nfb is still injected through those junction I see it now. Too many components to remove. I wonder I'd switching the impedance switch will do a difference, but you have to check. First take off those 100k resistor you just puted. Then measure the resistance between yellow and red points switching the impedance switch in one side than in the other."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostOk I see now. Well you tested nothing valuable in principle cause the nfb circuit was not opened. You removed those link between blue/green points but nfb is still injected through those junction I see it now. Too many components to remove. I wonder I'd switching the impedance switch will do a difference, but you have to check. First take off those 100k resistor you just puted. Then measure the resistance between yellow and red points switching the impedance switch in one side than in the other.
Your v6 phase inverter is still conected to output jack. If you want to check if oscillations are due to nfb issue you have to disconect it. But there are still 2 components into the link 100k nfb resistor on a side and 1M+100k in the other. You have to broke the circuit where I put the yellow line. Yo may cut the cooper trace and restore then with a wire between soldering points or you have to lift one terminal of each 1M resistor and 100k resistor. Then you will have not nfb injected and see if oscillate in open loop. The ideea is to make it stable without any nfb injected then will build the nfb circuit around.Last edited by catalin gramada; 03-09-2022, 03:42 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
No take it out first and power on. Those cooper trace from old blue point to v6 is the trace which inject nfb signal to v6. You should have nothing conected to it for the moment. You may cut exactly where I show you with yellow line than we restore the circuit with a short solid wire from solder joint to solder jointLast edited by catalin gramada; 03-09-2022, 04:03 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostNo take it out first and power on. Those cooper trace from old blue point to v6 is the trace which inject nfb signal to v6. You should have nothing conected to it for the moment. You may cut exactly where I show you with yellow line than we restore the circuit with a short solid wire from solder joint to solder joint
Originally posted by catalin gramada View PostNo take it out first and power on. Those cooper trace from old blue point to v6 is the trace which inject nfb signal to v6. You should have nothing conected to it for the moment. You may cut exactly where I show you with yellow line than we restore the circuit with a short solid wire from solder joint to solder joint2 Photos
