Have you tried this unit without your light bulb limiter? It may be the cause of the fluctuating signal.
Behringer GMX110 - 20vDC at Speaker Output
Originally posted by 52 Bill View PostHave you tried this unit without your light bulb limiter? It may be the cause of the fluctuating signal.
Thanks Bill, that is exactly what it was, works fine on the 4x12 without the Light bulb limiter...
This Forum Rules!
I am having trouble finding a cheap enough 4ohm speaker for this thing in the UK, with it being a transistor amp, would I have any problems putting an 8 in other than a slight loss in volume?
Cheers
Nick
No, go right ahead. The 3db loss is minimal and the amp will run cooler.
SOmetimes it is cheaper to buy or be given a broken small amp to take a speaker from than to buy a speaker alone.Education is what you're left with after you have forgotten what you have learned.
