JBL EON 515XT No Power On
  • JBL EON 515XT No Power On
    Getting 120vac to main board, 10 pin connector from controls has 0vdc on all pins.
    TP601-TP602 and TP601-TP603 both read (2k ohms and rise). TP-603-TP602 starts at(2k ohms) drops to (1.7k ohms) then slowly rises to (1.9k ohms) and stops. Not sure if that qualifies as bad?
      U402 is not shorted to heat sink. R626/628 read(10 ohms).
        R623/624(1k ohms)
        Q370-373(not shorted)
        Q601-606(not shorted)
          EON515.pdf
          Eon 515 Troubleshooting Guide.pdf
          E515 PWA Sch.pdf
          E515 IO Mixer.pdf
          E515 Parts List.pdf
          See if any of this helps you.
          nosaj
            Originally posted by nosaj View Post
            [ATTACH]n970218[/ATTACH]
            [ATTACH]n970219[/ATTACH]
            [ATTACH]n970220[/ATTACH]
            [ATTACH]n970221[/ATTACH]
            [ATTACH]n970222[/ATTACH]
            nosaj
            Got it, Thanks.
              C645 looks melted but has voltage up and down (reversing leads on resistance range). Bought this after testing good, got it home and no power on.
                C645 Click image for larger version
                  Removed C645 and of course it tests bad. Will replace.
                    Installed new C645 and power came on. Turned off to plug in a signal and now no power on.
                      To start-
                      check items: U601, U609, Q608, K600
                      check voltage: VBULK, +15 Control (U608)
                        Thanks for the info. Haven't worked on one of these before. Am I good trying to check voltages on these with speaker disconnected and no power on situation. Do I need an exterior power source? Thanks.
                          NO
                          Q608, K600, RC beside- check with the device
                            if your level of knowledge does not correspond to the topic of repair, give the device to a specialist​
                              this product is difficult to repair, requires good knowledge in circuit engineering.​
