I've just started looking at this stereo amp someone brought me. Chassis is intact, all OT secondaries cut at the speakers, and crossover tweeters disconected.
Will be a pretty big project. I've got all the original tubes in a bag. Apparently this has been passed around a couple techs over the years
Thusfar the only thing that I'm confused about is the selenium rectifier , that's not on the schematic.
You can clearly see the bias circuit : yellow/black bias tap> reversed diode>cap>voltage divider . You can also see that someone added a GIANT bias cap, which is essentially in parrallel with the smaller old metal bias cap.
They both are oriented correctly, + to ground, but this is the only modification I can find in the chassis, and a red flag.
Anyways, should I replace the selenium rectifier? Also, I'm just not really clear on why it's there? Isn't the little black diode doing the job to create neg voltage?
Schematic and pics attached
