Magnatone 280 restoration
  • Magnatone 280 restoration
ID:	992223 Click image for larger version
ID:	992224 Click image for larger version
ID:	992225 I've just started looking at this stereo amp someone brought me. Chassis is intact, all OT secondaries cut at the speakers, and crossover tweeters disconected.
    Will be a pretty big project. I've got all the original tubes in a bag. Apparently this has been passed around a couple techs over the years
    Thusfar the only thing that I'm confused about is the selenium rectifier , that's not on the schematic.
    You can clearly see the bias circuit : yellow/black bias tap> reversed diode>cap>voltage divider . You can also see that someone added a GIANT bias cap, which is essentially in parrallel with the smaller old metal bias cap.
    They both are oriented correctly, + to ground, but this is the only modification I can find in the chassis, and a red flag.
    Anyways, should I replace the selenium rectifier? Also, I'm just not really clear on why it's there? Isn't the little black diode doing the job to create neg voltage?
    Schematic and pics attached
    All I can think is that the small diode was a mod as well, and originally the amp didn't have it, just the selenium rec, but I'm not sure this was implemented correctly
      I guess the selenium rectifier was the original bias diode.
      Now it's out of circuit and replaced by the SS diode and can be removed.
        Ah I see, I didn't take enough time to see the neg terminal of the selenium rec is disconnected . Thank you.
        I'm gonna snip out the strange large replacement, replace the stock bias cap and diode mod with fresh ones and move on.
          Why is there a .1 blue molded cap as the second filter in the bias supply? Would another 25u/50v electrolytic be more effective?
          I happen to be working on another magnatone of my own, and the last filtercap in the main Power supply it 47n.
          What is the purpose of non-polarized caps in these applications?
            Also of interest, the NFB was disconnected from both poweramps you can see the green wires wrapped round some other wires after being snipped
              The impedance of a capacitor is a function of capacitance and frequency. So perhaps they were trying to deal with a specific problem in the bias supply. Or trying to lower the esr.
              Low value capacitors are typically non-polar. I think ideally all capacitors would be non-polar but we use electrolytics because they are much cheaper when capacitances are higher.
                Non-polarized caps are not required here.
                I can't think of a technical reason why they used such low capacitance.
                But before doing any component changes I would get the amp working.
                You could always add larger value ecaps later if there's a hum problem.
                  RFI maybe?
