I would probably need to change these ugly looking wires with better quality if i want my amp wired 16 ohms in series. Is this the correct wiring after setting the impedance selector to 16 ohms? If not please advise properly before i turn the amp on. Im heading to the chinese electronic shop to buy new wire and terminals. Speakers are 8 ohms each.
Correct wiring 2 x 12 fender red knob twin in series
This has all been covered in your previous thread about the amp. I'm not sure why you started another thread about the same amp anyway, but there's no need to rehash information that has already been discussed in the other thread."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
I've never read about any common "low mode" failure for these amps. So the first thing to check would be voltages in circuit. The mode switch in and out first. Then upstream along the high voltage supply until you see a problem. If this is confusing you and you have any concern working with the high voltage circuits in live amplifiers you should take it to a qualified service technician."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI've never read about any common "low mode" failure for these amps. So the first thing to check would be voltages in circuit. The mode switch in and out first. Then upstream along the high voltage supply until you see a problem. If this is confusing you and you have any concern working with the high voltage circuits in live amplifiers you should take it to a qualified service technician.
If the amp used to work on Lo mode with the old cement power resistor and original filter caps what could have happened? I also changed the 4 power tubes with a matched set.
Can you please re link the schematic on this thread if you have one."Take two placebos, works twice as well." Enzo
- Likes 1
Originally posted by Chuck H View PostCan you please re link the schematic on this thread if you have one.
Originally posted by Jquijano View PostYellow wire became loose. Ill resolder this back and revert...
Also note that your photo shows a push on mechanical connection that came loose. Just push it back in place. No soldering required.
OP: So, you flag my post as "rude and counter productive"? I was actually taming it down on that post, but since you're going to flag me anyway, here's what I WANTED to say.
You asked for advice and were advised by multiple career/qualified/exceptional techs (and myself) not to replace parts that didn't need replacing and that it could cause more problems rather than fix any (see this thread: https://music-electronics-forum.com/...-knob-twin-pcb). You willfully ignored that advice and, as expected, caused more problems than you fixed. Then, you come back here and ask the same techs that you ignored to bail you out. These guys donate their time for free to help guys like you and you're intentionally wasting it. You wanna know what's "rude and counter productive"?............ THAT!Last edited by The Dude; 02-03-2024, 01:37 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 5
Originally posted by The Dude View PostOP: So, you flag my post as "rude and counter productive"? I was actually taming it down on that post, but since you're going to flag me anyway, here's what I WANTED to say.
