Assuming a perfectly-efficient amplifier, 24V*5A = 120W so ideally possible.
50W into 8R (from the spec page) would require +/-20vdc rails in a linear amp. I'm thinking class D may get a single 24v rail to squeeze out that power. So how close to perfect is the amp? 100W/120W = 84% if we're talking continuous power output. I think class D amps approach that.
"Music Power" or "Peak Power" can be claimed, then all you need is a couple decent-size capacitors to hold the rails up for a few milliseconds.
So I guess the question as I would frame it, is whether "Carvin pedal can produce" or "Carvin can claim this pedal can produce"
Why should I eat steak and potatoes when I could just eat protein paste?
Why would I eat chicken wings when I could eat escargot? Probably because I've been culturally indoctrinated in one and not the other. It's not a value statement, but a statement of preference.
Yea well I prefer my indoctrination but thighs are better
nosaj
Binkie McFartnuggets:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
People with seafood allergies may be allergic to cricket flour.
It was two 50W outputs. Each will be bridged to give you about a 20Vpp swing, That's a full 50W average ( commonly misnamed RMS) into 4 ohms. Frankly, at USD189 with no preamp it seems overpriced.
On the USS Enterprise, grasshoppers will be made from protein paste. So OK For those with seafood allergies.
I noticed that the spec doesn't say RMS - it just refers to 100W or 50W+50W so could be music power.
I have a really cheap 100W 24v class D amp board from China built around a TI single chip. With a low-voltage tube preamp the sound quality is there, plus it's insanely loud and more than enough volume for live work. The input impedance is selected by a single resistor but unfortunately with my particular board it's inaccessible without removing other components, so the input impedance is pretty much set at 10K. Not a problem though with a preamp that expects to see a lower impedance. I tried driving it off a few pedals and it's pretty loud enough, but loses all the top-end as you'd expect.
I posted elsewhere what it cost and I can't recall exactly, but you could buy two for the price of a decent set of strings when I got it about 4 years ago.
